| | | Forums66 Topics128,168 Posts1,057,098 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 45 Member | | Member Joined: Oct 2003 Posts: 45 | ...But I like my creature comforts.
So I just scored a pair of ~95-98 Dodge Ram truck power mirrors & mounting brackets for $20.50 on ebay & $15 shipping
Ebay Item 7955939822
A few weeks ago a friend of mine and I were talking about how similar the mirrors looked between his lifted '97 Ram and the mirrors on my last truck (a '72 C10). Except his were power and mounted a little differently. Found a cheap set on ebay and bid on them
So I'm going to rig up some way of mounting these (hopefully reusing the GM mounting bases/bolt holes) and figure out how I'm going to add a joystick to my dash and wire these babies in.
The auction says theres a couple small spots on the chrome, so I figure once I get everything figured out and drilled/modified as necessary i'll strip the electronics out of the mirrors, scuff up the housings with sandpaper and powdercoat them onyx black to match my headlight doors on my '72 Cheyenne.
Should look almost exactly like the factory mirrors from the 67-72 pickups, except that these will be power | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Sounds like a good plan, Kris. Go for it! As for making any purists mad, well I consider myself a purist. The only way you could make me mad is if you did that to MY truck  As it is, we're glad you're having fun and making your truck the way you want it (and to heck with what the rest of us think  ) Regards, John
~ One of many.
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Oh yeah -- be sure to take pictures as you go along so you can write a Tech Tip for us!
Thanks, John
~ One of many.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | | | |
