| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 19 | Has anyone ever seen a firewall mounted device for supporting the hood on (say) 36 to 38 trucks with the three-hinge hood. What vehicles were these used on. Were they used (perhaps) on GMCs only? Or perhaps they were aftermarket. I've always seen the hood corner resting atop the cowl.
PatM
From Sunny California Forever working on the '37 Under the shade of my dreams
| | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | PatM: I haven't seen a firewall mounted one, but Jim Carter sells on that mounts to the support bars that go between the firewall and the top of the radiator support. It has two little arms (one on each side) that flip out to hold the bottom edge of your hood. There's a 46 in the gallery that I remember seeing it on, but I don't remember just now, which truck it was. There was also a discussion about a month or so back on this same topic. Good Luck. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | PatM: Check E-Bay item #4524216240. The auction has ended, but he has a link to a website showing more pictures of the truck. One of the pictures will give you a good idea of the support I'm talking about. | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | | | | | | Joined: Jul 2000 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 19 | Thanks guys. Jed -- I've seen similar units to the one in the photos of the '46. They do work well, and I have considered them. But then I "heard-tell" of a set of "OEM" or, perhaps "back-in-the-day" accessory items that mounted on the firewall. I thought having "period" hood props would be kinda kool.
Randy -- Thanks very much for the link. I'm an engineer (of sorts) and the very technical type presentation on the link you sent is mind boggling. I need to try to look around a little more on that web site. BTW. . . This is yet another variation. The units I was enquiring about mount on the firewall, with their own mounting. But the link you sent uses the core support rods very near the firewall interface. Very neat. And the Plasti-Dip is a real nice touch too.
Thanks again to you both.
Pat
