2 members (ShopRag, GradyB),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Just received an email from a party interested in purchasing my truck. This guy is located outside the U.S. and asked the question as to whether I knew if the 59 could be converted to right hand drive. Just wondering if anyone has ever seen a right hand drive stovebolt before. :confused:
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Sure! I saw a 57 1/2 ton with a right hand drive at the Fort Worth Goodguys show last Oct. It was made in South Africa. How you would go about changing a lefty to a righty is the question. Mods to steering and sheet metal are certain. I think you would also have to change the speedo to read right to left also.  | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Bruce! Check out the following link. Scroll down the pictures and you'll find a good photo of a right hand drive truck. We won't tell anyone what 'brand' it is but you can be sure that GM's had the exact same setup. The instrument panel is the same, left or right, the levers are not changed nor are the switches. It's just that the driver's position is on the 'other' side. http://www.geocities.com/cmpvehicles/beltring_cmp.html Cheers, George | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | It's very easy to convert an old truck over to RHD, especially pre-1960 or so. There are indentations in the firewall, floorboard, and on some, the inner fenders that allowed the factory to build whatever was necessary easily. The only real mechanical differences on most is the headlight shift (LHD is to the right, RHD to the left), wiper sweep (usually the opposite, to conform with AU/NZ/UK/SA/JA laws), and the obvious things like master cylinder placement and such. No differences in instrumentation or even floor pedal placement (same as LHD). Shifting with the left hand gets a little getting used to, though!
A conversion on old trucks isn't a big ordeal.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I can't speak to Task Force trucks, but the assembly manual for Advance Design trucks shows all the things that are different between RH and LH drive.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Originally posted by Bruce K.: Just received an email from a party interested in purchasing my truck. This guy is located outside the U.S. and asked the question as to whether I knew if the 59 could be converted to right hand drive. Just wondering if anyone has ever seen a right hand drive stovebolt before. :confused: TASK FORCE RHD | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you\'ll notice there\'s a bit of dash difference in RH drive TF trucks - kinda hard to drive from the 'passenger seat' when the speedo and gauges are on the other side!! if ya look at the assembly manual, there's an endless amount of difference, but why bother? there's folks that drive right hand drive trucks on this continent, and lots that drive ours in areas they usually have right drive rigs Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Be very leery about someone overseas wanting to buy your truck. There is alot of scamming going on. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | They are pretty much all RHD here ,, what country is your prospective purchaser from. | | | | | Joined: Jan 2005 Posts: 8 Junior Member | | Junior Member Joined: Jan 2005 Posts: 8 | Hey there Dusty! Go Canterbury! Dont know about other countries, but here in NZ, if a car is over 20 years we dont have to convert it to rhd-it can be registered in original configuration.
aaahh..the smell of my old truck...
