| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17798 02/09/2005 5:22 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I am confused as to how tight to make the front wheel bearing nut. The Factory Manual says 400 inch pounds. Does that mean 400 divide by 12 +33.33? | | |
#17799 02/09/2005 5:54 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 400 in-lb divided by 12 = 33 ft-lb. Set your wrench to 35 ft-lb. Turn the drum while tightening so the bearings are seated. I usually will tighten once, back off and repeat the turning and tightening step. The back off 1/12 to 1/6 of a turn to insert the cotter pin.
Fred 52 3600 69 C-10
#17800 02/09/2005 10:16 PM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Fred, is 35# the normal for most all trucks? I replaced my wheel bearings with the roller type. Cecil.... | | |
#17801 02/10/2005 8:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The torque specs will be a bit differant for roller bearings.
#17802 02/10/2005 8:17 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I have roller bearings so what do I torque them to? | | |
#17803 02/11/2005 2:37 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 20 ft-lb for roller bearings.
