2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
I am confused as to how tight to make the front wheel bearing nut. The Factory Manual says 400 inch pounds. Does that mean 400 divide by 12 +33.33?
400 in-lb divided by 12 = 33 ft-lb. Set your wrench to 35 ft-lb. Turn the drum while tightening so the bearings are seated. I usually will tighten once, back off and repeat the turning and tightening step. The back off 1/12 to 1/6 of a turn to insert the cotter pin.
Fred
52 3600
69 C-10
Fred, is 35# the normal for most all trucks? I replaced my wheel bearings with the roller type.
Cecil....
The torque specs will be a bit differant for roller bearings.
Paint & Body Shop moderator
I have roller bearings so what do I torque them to?
20 ft-lb for roller bearings.
Fred
52 3600
69 C-10
