9 members (VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, artinva, klhansen, Otto Skorzeny, 1 invisible),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17731 08/10/2002 9:43 PM | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | If I put a 3.40 rear end in my 66 would I have any problems going 70 on the interstate. I plan on having it on the road quite a bit. I have a 350 with a turbo 350 transmission in it. thanks | | |
#17732 08/11/2002 2:02 AM | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | I run 3.07 with a 200R4, 1700 at 60, pulls real nice for me.
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
#17733 08/11/2002 3:53 AM | Joined: Dec 2000 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2000 Posts: 54 | Your looking at about 2850 rpm's at 70 with 28" tires (common on 15" wheels) or 2660 with 30" (common on 16's). You'd probably be looking for OD about then..... | | |
#17734 08/11/2002 5:36 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You might want to consider going with a 3.08. Does pretty good in my 69 with 350/ th400.
Fred 52 3600 69 C-10
