5 members (78buckshot, Jeff Ogden, Otto Skorzeny, KingG, 1 invisible), 39 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#177309 05/14/2005 4:04 AM
Junior Member
Junior Member
I have about 200 miles on 59 235 with solid lifters, about 2/3s of the miles are driving going on short trips in town going through the gears. An the rest is on the country roads taking it up to 50mph for short periods of time.Is this the right way to break it in.
Thanks for any feed back
annalei0
#177310 05/14/2005 12:26 PM
Thats the way manuels used to describe, just don't stay at one rpm for great lenght of time. Don't know how many folks actually followed that advice though
#177311 05/14/2005 5:39 PM
Junior Member
Junior Member
hopefully you've already changed the oil once
#177312 05/16/2005 3:57 AM
This is how I break my motors in that I have build, three six, four v8's chevy of corse. after getting every thing set and the cam broke in, 2000 rpm for 20 min. I run it as hard as I can like the way that I will drive it later. if its going to break it will do so then. with the six's I go do hard burn out's 5 to 15 min. each with old tires to run the rpm up high. the six that is in my truck now is 19 years old. after the rebuild. know a lot of people that Baby the motors for the first 500 miles and the first time the stood on it it broke something. with all of the engines that I have built none have give me any problems.
super250six
#177313 05/16/2005 1:29 PM
8
8 Offline
I just drove mine like normal, but I made sure to vary the RPM's every so often. First oil change at 200 miles.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
