2 members (dunfire, WICruiser),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 3 Junior Member | | Junior Member Joined: Apr 2005 Posts: 3 | Hi Guys; Guess i'm the newest guy on the block. In a nutshell; Will a 2 ton cab fit on a 1/2 ton chassis? Will my 1/2 ton fenders and hood fit to the contours of the 2 ton cab? Thanks for your help, Eddie
| | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Jerry,
I'm sure you're going to get this response, so without trying to be a smart @*@ I'll be the first to ask. What year truck are you talking about? That said, my guesss would be probably not, but I'm sure someone else here has tried it? Good Luck. | | | | | Joined: Apr 2005 Posts: 3 Junior Member | | Junior Member Joined: Apr 2005 Posts: 3 | Sorry, both are 1947,1st series. Eddie
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, what year? oh! ok but actually regardless of year, all the cabs I've seen [assuming it's not a COE] are the same for any size, and your front sheet metal should fit, but there may be small things they made different to fit the larger frame and fenders, so you might have to adapt a bit
Bill | | | | | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | It's funny you ask, because just today I ran the numbers on what I thought was my '46 half ton pickup. I just picked up the mechanical and model identification data and it turns out it (well the cab for sure) is a '45 2 ton. Everything else is half ton though, ie shortbox, frame, front sheetmetal. So yes, a 2 ton cab is the same.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | jerry if you go to the features under big trucks. this may answer a lot of your questions. link http://www.stovebolt.com/features/bigtrucks/ good luck with your project. got to love those big bolts..mike j | | | | | Joined: Apr 2005 Posts: 3 Junior Member | | Junior Member Joined: Apr 2005 Posts: 3 | Thanks guys, Looks like some minor mods might be in order, but i can handle that. while asking questions today about the newly acquired 2 ton cab, I was told they are generally more rust free because they are higher from the ground (water, muddy roads, fields ect.) Probably under a shed too in the winter. Makes sense to me. Thanks for your comments. Eddie
