9 members (49fastback, HandyAndy, Otto Skorzeny, Eisenholtz, jmoore, Joe H, GMCJammer51, 66flea, 68ironhead), 92 guests, and 2 robots.
Topics128,035
Posts1,055,570
#176996 04/02/2005 12:16 AM
Junior Member
Junior Member
Hi Guys; Guess i'm the newest guy on the block. In a nutshell; Will a 2 ton cab fit on a 1/2 ton chassis? Will my 1/2 ton fenders and hood fit to the contours of the 2 ton cab? Thanks for your help, Eddie
#176997 04/02/2005 12:20 AM
Jed Offline
Jerry,
I'm sure you're going to get this response, so without trying to be a smart @*@ I'll be the first to ask. What year truck are you talking about? That said, my guesss would be probably not, but I'm sure someone else here has tried it? Good Luck.
#176998 04/02/2005 12:42 AM
Junior Member
Junior Member
Sorry, both are 1947,1st series. Eddie
#176999 04/02/2005 12:42 AM
yeah, what year? oh! ok
but actually regardless of year, all the cabs I've seen [assuming it's not a COE] are the same for any size, and your front sheet metal should fit, but there may be small things they made different to fit the larger frame and fenders, so you might have to adapt a bit
#177000 04/02/2005 2:11 AM
It's funny you ask, because just today I ran the numbers on what I thought was my '46 half ton pickup. I just picked up the mechanical and model identification data and it turns out it (well the cab for sure) is a '45 2 ton. Everything else is half ton though, ie shortbox, frame, front sheetmetal. So yes, a 2 ton cab is the same.
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#177001 04/02/2005 2:50 AM
jerry if you go to the features under big trucks. this may answer a lot of your questions. link
http://www.stovebolt.com/features/bigtrucks/
good luck with your project. got to love those big bolts..mike j
Drive with Pride. mike j
family pic
#177002 04/02/2005 2:56 AM
Junior Member
Junior Member
Thanks guys, Looks like some minor mods might be in order, but i can handle that. while asking questions today about the newly acquired 2 ton cab, I was told they are generally more rust free because they are higher from the ground (water, muddy roads, fields ect.) Probably under a shed too in the winter. Makes sense to me. Thanks for your comments. Eddie
