0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Do 55-59 3/4 ton dually have 1ton rear ends? I heard that 3/4 ton dually are equipped with 1 ton rear ends from the factory. | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | A 3/4 ton with dual wheels? Was that a factory option? I believe the center section is the same, but the hubs and brakes might be different to accomodate the dual wheels. My 59 1-ton has much bigger brakes than a 3/4 ton, enough that 16" wheels won't fit. It needs 18" wheels to fit over the drums. Jerry
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If there is a difference between the H052 and the H070 axle, I haven't found it yet. | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Brake size and gearing options were about the only differences between 3/4 and one ton axles. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | So are 3/4 2 wheel axel cylinders the same as 3/4 ton dually wheel cylinders? | | |
