Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#17656 06/12/2004 6:30 PM
Iput new points in my 235,changed the wires,check the gap 3 times.Its set at .019.It starts right up andsounds good at idle but runs rough at high rpms.What have i done wrong.i checked and rechecked the fireing order.Ive sinse lowered the points to .018,still rough at high revs.Also tried a different rotor.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#17657 06/12/2004 8:09 PM
H Online: Content
Check the ignition timing. a 1 degree change in dwell (determined by the point gap) changes ignition timing 2 degrees. You might have it over-advanced at high RPM.
#17658 06/12/2004 9:25 PM
Bushings may be "gone" in your dizzy, causing your dwell to vary wildly.........check with engine running and meter connected. Idle dwell may look okay, but increase RPM's to see if the meter starts to fluctuate. This is a common problem on old or highmileage engines.
If you don't have a dwell meter, borrow one..........either that, or pull the dizzy out, put it in a "soft-jaw" vise and check for lateral play and excessive run-out in the bushings.
Distributor can be rebuilt or just find one that isn't as worn.
Also, how worn down is the cam that opens the points? If it's worn down enough it will not run well above an idle. Lack of coil saturation.
These are only suggestions and are only worth what you paid for them wink smile .
*** GMC ***
#17659 06/12/2004 9:43 PM
All of the problems started after i fixed it :DThis engine has run great for the last year.I had the distributor out and it seems ok.The advance is working.After it didnt start a week ago i checked all electrical conections and put in new points.Moveing the distributor doesnt get rid of the problem.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#17660 06/12/2004 11:36 PM
My old 235 starting missing at higher RPM's such as just before shifting to the next gear. I cleaned out the hardened grease in the grease cup on the distributor and put new grease in it. That solved my problem.
#17661 06/13/2004 1:24 AM
Turns out the spare part...was the spring and with out it the points were floating. :rolleyes: Back to running smooth.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#17662 06/13/2004 2:03 AM
Hey Slow rider,
I recently placed a new 235 into my 49 Chevy truck, and when we got it running, it did the same thing. I did all the same things you did, and just couldn't figure out why it missed when we reved up the engine. The coil was the only thing I hadn't replaced. I put a new coil on it, and it solved the problem. Just a thought!
KT
1949 5 window 3/4 ton
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
