5 members (BC59, Otto Skorzeny, Gdads51, Hotrod Lincoln, 1 invisible), 93 guests, and 3 robots.
Topics128,089
Posts1,056,354
Members48,442
Anyone out there ,install the power steering converison from CPP,on thrir trucks? OLD NAVY 51.............. wink
A friend of mine bought the kit but never installed it. Don't know if he still has it or not. What do you want to know?
OldSub- I'd like to know- my 54 has always been a [censored] to steer. I love to buy a power kit.
Dale
you may need to work out more,,just kidding, my 52 is not all that bad,,, in a real tight parking, like parallel,, you have to use a little more ump,,,but other then that no big deal...
Redryder pix
My Hotrod
grin grin No doubt why "Joker" has his name.
Once you get that truck in a straight line, you don't need no power steering. wink
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
My '55 1st Suburban is a lot easier to steer when I drive it everyday. Maybe not the first week, but afterward I no longer notice...
microbe, what do you want to know? Either he sold the kit with the truck, or took it with hime when he moved to Colorado. I'll ask him if you'll tell me what to ask.
Thanks for all the replys,the main reason that I was thinking of going to power steering are. #1 the steering column is to high. #2 I would like to put on a smaller steering wheel. #3 changing to a modern power saginaw steering box will give a better or closer ratio as well as the power steering . I drive my truck a lot And items like better brakes ,steering etc are important . old navy 51..............
Put an M2,with power R&P steering in my 55 2nd,what a difference.Its a real pleasure to drive.
