4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Earlier today I looked up okie bushing in the Search section and got a bunch of leads. Just tried it again and it acts as if it never heard of it. Where did I go wrong? In Search I mean. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Bill: Make sure you select the correct forum you want to search. It defaults to the last forum you were in. So, if you go from here to search, you will only search "general truck talk". Select "engine and driveline" and you will get hits.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Gord tried them all and no joy. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I just got 20 hits for 'okie bushing' ... almost all from the Engine & Driveline Shop. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Tried it again. Went to Engine & Driveline shop. Went to Search and typed in okie bushing. Nothing. Says no matches for okie bushing. I am missing something somewhere. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Okay I found where I went wrong. I was going into the right Forum and then clicking on the Search at the top of the page where it lists all the items like Forums, Gallery, Tech Tips, etc. I should have clicked on search in small print on the Forum page. Thanks to all for putting up with me. | | |
