1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#176006 11/20/2004 12:53 AM
I have a '66 C-10 with a factory 3.73 and a 420 Muncie 4-speed (granny low) and a factory 327 cid. I would like to change out the ring and pinion setup for enhanced highway performance. What am I looking at for a new setup that will give me 2,200-2,400 rpm at a speed of 65-70 mph?
Your input is appreciated.
LILRED66
#176007 11/20/2004 2:03 AM
Swapping out to a 3.08 with a 30 inch tire diameter will net you about 2,400-2,450rpm. I don't know that you'd wanna go much higher than that. I'd think it'd turn your truck into a snail with a stock 327 in a big and heavy Chevy truck. It may even be a slug with a 3.08.
For a long time I thought I would just change out my ring and pinion for better cruising speed and that everything would be hunky dory. Turned out nobody made gears for the beefy 3/4ton rear (except Art Houser who makes a 3.90 for the lowly sum of $490) so I researched and researched and discovered the biggest gains were made doing a tranny swap with an overdrive unit.
Keeping your 3.73 and just swapping out to a .86 OD tranny gets you almost the same results as going all the way up to a 3.08.
Keep your 3.73 and swap to a tranny with a .72 OD and now you're at 2,100 rpm @ 70 mph.
I could be totally wrong about the 3.08. It might be great. Anyone else have thoughts on using a 3.08 with this setup?
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#176008 11/20/2004 3:47 AM
Quote
LILRED66
I had the same setup but with a 3 speed, column shift transmission. I changed the 3 speed to a New Process A833 4 speed. Got a .73 overdrive and now (with 235/75R15 tires) I turn 2200 rpms at 70 and a shade over 2600 rpms at 80. 70 is easy cruising with the 292 I have as it has headers, a mild cam and 500 cfm 4 barrel carburetor.
So I recommend the A833 New Process 3 speed + Overdrive transmission .
