| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Canadian model numbers on AD trucks are different to american-made ones. I would like to find out what a Canadian 1430 is. it is bigger than a 3/4 ton and has big rear leaf springs with 17 inch wheels. | | | | | Joined: Jan 2004 Posts: 10 Junior Member | | Junior Member Joined: Jan 2004 Posts: 10 | my guess is that it is a 1 ton, mine is a 1424 and its a 3/4 ton but if you have wheelbase measurements or inside box measurements that would help | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | iceberg, the truck belongs to a friend of a friend so the only thing I recall is the bed being 9 feet or so. thanks | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Could be a one ton or a 3/4 ton with the long box, I've got one of the long boxes in my driveway ... one ton I think as it has real heavy duty springs. | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | My documentation from GM Canada indicate the model 1400 is a "pickup delivery". It does not idicate a 1430 model but has the following information: Model 1424- 125 1/4 inch wheelbase; G.V.W. 5200-5800 lbs. Model 1434- 137 inch wheelbase G.V.W. 5700-7000 lbs.
GM Canada has a Vintage Vehicle Department. Their Customer Assistance Centre is at 1-800-263-3777.
Good luck! | | | | | Joined: Jan 2004 Posts: 10 Junior Member | | Junior Member Joined: Jan 2004 Posts: 10 | 3/4 ton box is 87" 1 ton box is 108" | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 1430 is the Canadian model number for the 1 Ton. The GMC version would be a 9430 such as my own 1 Ton. If it has single wheels on the rear, the GVW will be somewhere around 5800 lbs but with the duals, it goes up to 8000 lbs. The wheel base should be 137". I have the complete chart for the model numbers if you want them. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | It has single rear wheels but the 5800 pound GVW rings a bell. I have not seen the truck as it belongs to a friend of a friend. Thanks for the help. | | |
