4 members (Samantha, KEVINSKI, mk72, 55shaker), 91 guests, and 2 robots.
Topics128,035
Posts1,055,552
#175889 01/24/2005 3:13 AM
Apprentice
Apprentice
procedure /product for steering gear lubrication ?, Is 90 wt. tranny lube proper? how much is too much ? [email protected] chevy 3100. thanks !
rrf
#175890 01/24/2005 3:43 AM
50 chevy 3100,
This is a question that comes up every so often. The original lube is not available. A product called Penrite Steering Box Lube is an excellent replacement (but is not widely available).
Everyone seems to have their own opinion on what to use and why.
I use chassis grease (I think the original steering box lube was equivalnet to 1200 weight oil/grease).
To see more opinions. Use the "search" feature above. search on the string "steering box" in all open forums. This will give you a few discussions on this topic.
Good luck,
Tim
#175891 01/24/2005 4:19 AM
I used "OO" gearbox grease for Snapper lawnmowers, seems to work well. Kinda thick oil/grease-like substance, it doesn't run out seals like 90wt. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#175892 01/24/2005 4:34 AM
Anonymous
Unregistered
Anonymous
Unregistered
I gave up usin' gear oil years ago.
I like to use " Mystick JT-6 " [The red stuff].
Its made by Citgo outta Tulsa OK.
This is a marine grade multi-purpose grease & it works great.
I get it at a local industrial supply shop.
Ask 'em for the red grease.
#175893 01/24/2005 7:39 PM
Here's the "Penrite" website. This is what I prefer..
http://www.classicautolubes.com/
