7 members (59 fleet, Wally / Montana, Brian Moore, KCMongo, Otto Skorzeny, Rusty Heaps, mo2cyl),
106
Mod | | | Forums66 Topics128,034 Posts1,055,539 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | procedure /product for steering gear lubrication ?, Is 90 wt. tranny lube proper? how much is too much ? [email protected] chevy 3100. thanks !
rrf
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 50 chevy 3100,
This is a question that comes up every so often. The original lube is not available. A product called Penrite Steering Box Lube is an excellent replacement (but is not widely available).
Everyone seems to have their own opinion on what to use and why.
I use chassis grease (I think the original steering box lube was equivalnet to 1200 weight oil/grease).
To see more opinions. Use the "search" feature above. search on the string "steering box" in all open forums. This will give you a few discussions on this topic.
Good luck, Tim | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used "OO" gearbox grease for Snapper lawnmowers, seems to work well. Kinda thick oil/grease-like substance, it doesn't run out seals like 90wt. Brian | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I gave up usin' gear oil years ago.
I like to use " Mystick JT-6 " [The red stuff]. Its made by Citgo outta Tulsa OK. This is a marine grade multi-purpose grease & it works great. I get it at a local industrial supply shop.
Ask 'em for the red grease. | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Here's the "Penrite" website. This is what I prefer.. http://www.classicautolubes.com/
