3 members (WICruiser, NorCal52Suburban, GMCJammer51), 90 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
Y
Junior Member
Junior Member
Y Offline
I see the $1,200 conversion kits available, but how to do it on the cheap?
I understand they were factory available starting '71.
Is there a simple component swap from later years using salvage yard parts?
A good friend will bail you outta jail...A true friend will be sitting next to you saying, "That was FUN!"
Send us your injured child:http://www.shrinershq.org/hospitals/index.html
Its possible to swap the entire IFS from a later truck to your '69. '63 to '87 are all very similar.
I'm doing it on my 70, using 72 spindles, ball joints, & linkage. Also will upgrade to 71-72 master & proportioning valve. Use front hoses from Early Classic Ent. or run new lines for front. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Riding in the Passing Lane
You will wind up with 5 hole wheel patern
You can change to a 71-2 rear end or change
axles & drums. smile
1972 Chevy c10 Cheyenne Super
Z
Z Offline
you can get six lug rotors.i getting ready to change back to five lug rotors to match my **** rearend.
Previous owner of my '67 said the '75 front end bolted right up real easy.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Y
Junior Member
Junior Member
Y Offline
Thanks, gents.
I guess that answers my questions. smile
The main difference in the 71-72 and 73 up is the screw in A-arm bushings compared to the press in bushings on the 73 and up. I like the screw-in myself.
Some steering pieces (drag link and idler arm) are a little different as well.
