1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 43 Junior Member | | Junior Member Joined: Sep 2004 Posts: 43 | I see the $1,200 conversion kits available, but how to do it on the cheap?
I understand they were factory available starting '71.
Is there a simple component swap from later years using salvage yard parts?
A good friend will bail you outta jail...A true friend will be sitting next to you saying, "That was FUN!"
Send us your injured child:http://www.shrinershq.org/hospitals/index.html
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its possible to swap the entire IFS from a later truck to your '69. '63 to '87 are all very similar.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I'm doing it on my 70, using 72 spindles, ball joints, & linkage. Also will upgrade to 71-72 master & proportioning valve. Use front hoses from Early Classic Ent. or run new lines for front. Brian | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will wind up with 5 hole wheel patern You can change to a 71-2 rear end or change axles & drums.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | you can get six lug rotors.i getting ready to change back to five lug rotors to match my **** rearend. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Previous owner of my '67 said the '75 front end bolted right up real easy.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Sep 2004 Posts: 43 Junior Member | | Junior Member Joined: Sep 2004 Posts: 43 | Thanks, gents. I guess that answers my questions.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The main difference in the 71-72 and 73 up is the screw in A-arm bushings compared to the press in bushings on the 73 and up. I like the screw-in myself. Some steering pieces (drag link and idler arm) are a little different as well.
