0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17531 04/25/2002 3:10 AM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | Okay, I've heard you set timing my the valves?? Well, I want to do the easy method, what should it be using a light on the flywheel? 0 or something like 5? It runs, has power, but is blowing sparks out of the pipe. It is a little ruff sounding but not sure if the carb is out of adjustment or what. I assume I need lead additive also? | | |
#17532 04/25/2002 1:11 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Attach timing light to #1 spark plug wire. Run engine at ideling speed. Loosen distributor clamp and rotate distributor body until the steel ball on the flywheel lines up with the pointer on the flywheel housing. Tighten the distributor clamp. The timing hole is on the starter side of the flywheel.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#17533 04/25/2002 1:39 PM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | | | |
#17534 04/25/2002 4:54 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | not "0 degrees" but 5 degrees BTDC.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#17535 04/25/2002 6:13 PM | Joined: Apr 2002 Posts: 50 Member | | Member Joined: Apr 2002 Posts: 50 | But the BB is TDC right? So I need to set the light on 5 or is the BB 5 BTDC? | | |
#17536 04/25/2002 9:30 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 |
