0 members (), 80 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
I
I Offline
Okay, I've heard you set timing my the valves?? Well, I want to do the easy method, what should it be using a light on the flywheel? 0 or something like 5?
It runs, has power, but is blowing sparks out of the pipe. It is a little ruff sounding but not sure if the carb is out of adjustment or what.
I assume I need lead additive also?
Attach timing light to #1 spark plug wire.
Run engine at ideling speed.
Loosen distributor clamp and rotate distributor body until the steel ball on the flywheel lines up with the pointer on the flywheel housing.
Tighten the distributor clamp.
The timing hole is on the starter side of the flywheel.
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
I
I Offline
So 0 degrees then.
Oly Offline
not "0 degrees" but 5 degrees BTDC.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
I
I Offline
But the BB is TDC right? So I need to set the light on 5 or is the BB 5 BTDC?
The bb is 5 btdc
Paint & Body Shop moderator
