3 members (Donf, tclederman, 1 invisible), 72 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
Junior Member
Junior Member
I would like to raise the front approx. 2 inches. Any recomendation on how to do this?
New coil springs from a full loaded " V8, a/c, p/s, p/b, cc etc.;" Camaro of the same year should do the trick.
Joe
Just be sure the rebound snubbers allow the suspension to drop a little more as the weight comes off the suspension. If it's on its lower limit, you'll bounce the wheel off the ground when it drops into a pothole, and a wheel that's up in the air can't steer or stop!
