| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 1 Junior Member | | Junior Member Joined: Sep 2004 Posts: 1 | I would like to raise the front approx. 2 inches. Any recomendation on how to do this? | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | New coil springs from a full loaded " V8, a/c, p/s, p/b, cc etc.;" Camaro of the same year should do the trick.
Joe
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Just be sure the rebound snubbers allow the suspension to drop a little more as the weight comes off the suspension. If it's on its lower limit, you'll bounce the wheel off the ground when it drops into a pothole, and a wheel that's up in the air can't steer or stop! Jerry
