5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
I think I've figured it out - -
I recently did an antifreeze flush as some of you may remember, and realized that the resevior will be empty every now and then. Knowing Chevy radiators, it's probably leaking, but not too much. I think I may have pinned it down though. On the inner passenger side fender, towards the front, near the lights, there's a big HOLE. I originally just thought it was a rust hole, but could it be that the antifreeze is leaking from the resevior and dripping down the fender in this spot, which ate a hole? I don't know if antifreeze can do that, but thought I'd ask here. Thanks for the help!
GO RANGERS grin
Photos Updated so check them out!
Keep looking, antifreeze wont cause rust. Get your cooling system pressure tested at the local garage...save time and maybe your engine.
65 C10 292/700R4 long fleet...Gettin closer by the day.
Well, I don't mean that it caused rust, I mean maybe it ate a whole through the metal
GO RANGERS grin
Nope. Antifreeze isn't corrosive. It wont eat metal.
Gravity - It's not just a good idea, it's the law.
Ok so I have a question or two. Is your radiator cap new or old? What poundage is it>? How do you know that the radiator is low? I ask this because if everthing is working correctly shouldn't the extra fluid be drawn back into your radiator when the system cools off? Unless your "resevoir" is just a catch can. Then it should not empty itself but fill and fill and fill till it overflows or the level in your radiator levels off and stops spilling into your catch can.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
You got an 85? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Yup.
Okay, so it's not corrosive. hmm
Brian, it's an old cap, but it's still in great shape. When the engine is cool, the radiator is filled just to the right level, but there's nothing in the resevior, which is what I would expect.
Maybe a rubber hose is damaged, preventing it from going back to the resevior?
I'll check more
GO RANGERS grin
Junior Member
Junior Member
hardy , if memory is correct that is location of battery and now or previous leakage, terminal corrosion brushed, leaked etc. onto the metal will and has done just that, eaten a hole into the sheet metal.
