1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I think I've figured it out - -
I recently did an antifreeze flush as some of you may remember, and realized that the resevior will be empty every now and then. Knowing Chevy radiators, it's probably leaking, but not too much. I think I may have pinned it down though. On the inner passenger side fender, towards the front, near the lights, there's a big HOLE. I originally just thought it was a rust hole, but could it be that the antifreeze is leaking from the resevior and dripping down the fender in this spot, which ate a hole? I don't know if antifreeze can do that, but thought I'd ask here. Thanks for the help! | | | | | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | Keep looking, antifreeze wont cause rust. Get your cooling system pressure tested at the local garage...save time and maybe your engine.
65 C10 292/700R4 long fleet...Gettin closer by the day.
| | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Well, I don't mean that it caused rust, I mean maybe it ate a whole through the metal | | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | Nope. Antifreeze isn't corrosive. It wont eat metal.
Gravity - It's not just a good idea, it's the law.
| | | | | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Ok so I have a question or two. Is your radiator cap new or old? What poundage is it>? How do you know that the radiator is low? I ask this because if everthing is working correctly shouldn't the extra fluid be drawn back into your radiator when the system cools off? Unless your "resevoir" is just a catch can. Then it should not empty itself but fill and fill and fill till it overflows or the level in your radiator levels off and stops spilling into your catch can.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Yup.
Okay, so it's not corrosive. hmm
Brian, it's an old cap, but it's still in great shape. When the engine is cool, the radiator is filled just to the right level, but there's nothing in the resevior, which is what I would expect.
Maybe a rubber hose is damaged, preventing it from going back to the resevior?
I'll check more | | | | | Joined: Oct 2000 Posts: 10 Junior Member | | Junior Member Joined: Oct 2000 Posts: 10 | hardy , if memory is correct that is location of battery and now or previous leakage, terminal corrosion brushed, leaked etc. onto the metal will and has done just that, eaten a hole into the sheet metal. | | |
