3 members (Peggy M, RLB, 1 invisible), 96 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
I have a couple questions:
I don't know what this is called, so any help will do.
On my 305 V8, towards the top front of the engine, it's got a Y shaped thing. I think it's the water outlet? It bolts into the intake manifold. Well one part of it I think has the radiator hose going to it, and the other part has this beige plastic thing. It looks like a little cylinder, and has (on one side) 3 vacuums going into it. This thing is not even connected, it broke off. I have no idea what it is or does...
Any help on that?
The 2nd thing is the power windows. I've got em, and the motor died on me yesterday. I tried the old trick of popping it with a hammer/mallet. But it still won't go up, and if I'm going to change the motor, how do I get it to go up there?
Thanks guys
GO RANGERS grin
Photos Updated so check them out!
Sorry...85 Chevy 1/2 ton daily driver...
Not a stovebolt, but still...
305V8
GO RANGERS grin
Hardy,
That's a thermostatically activated vacuum switch. One of the plugs is vacuum in, and the other two would be switched output -- when the engine heats up, they get vacuum. They're common smog control items.
Brian
I hate this California emissions stuff - thanks though Brian.
Well, what was originally a 1 hour job with my dad turned into a 7 hour fiasco, with a new hole in my door, and my arm all cut up, and a whole bunch of other stuff.
but my goes up, and it goes down, quickly, so I guess I'm done! smile
Thanks guys
GO RANGERS grin
Moderator
Moderator
Power Windows... Gotta love 'em.
I've had to replace them on my '89 Suburban and the wife's '93 S10 Blazer, also two of them on a '90 Celebrity wagon I had for a while.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
