1 members (2-Ton),
111
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'm needing to reseal the power steering gear on my 69 C-10. I was looking in the overhaul book, and it appears that it can be done without the GM tools.
It's been too many years since I had one apart, and CRS is setting in on me. Is it feasible to rebuild one with standard tools?
Fred 52 3600 69 C-10
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If its just leaking, replace the seals w/a $10 seal kit. You really don't want to take one apart. Brian | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do it,,, then buy a rebuilt one for $128 bucks if it does not work or if you lose some of the pieces
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Wish I could get one for $128. I was shot a price of just over $200 from my local store.  AZone shows $150, but I don't trust their rebuilds. Checked here and on the 67-72 board, couldn't find anyone who tackled one and was willing to admit it. Looks like I better get out the camera when I do it.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The box I put in my brothers 70 GMC 4x4 (4? years ago is still working great. Local C ut R ate A uto P arts Use a digital video recorder (3 of them to cover all angles while doing the rebuild. Use the wide angle option so you can see where all the little parts run off to. WOrk in a small enclosed room that has no nooks and crannies for the pieces to hide. You will have all the parts even if you cannot remember where they go since you forgot to charge the battery on the video camera..... :p
| | | | | Joined: Sep 2004 Posts: 16 Junior Member | | Junior Member Joined: Sep 2004 Posts: 16 | I've done a Saginaw box without any special tools. Quite a while ago but it's still in service and working. Don't know yours specifically, but I'm under the impression that they're all pretty much the same. It's not a hammer and vise-grip job, but it's not beyond anyone with a bit of skill and patience. The only problem I ran into was having balls drop into the case while installing the worm. The worm will still thread smoothly so you didn't really know one had fallen in. J.
Edit: I remember I used an old Motor truck repair manual as a reference - it was enough. I could scan the pages and e-mail them if u like.
Stranded in time. Surrounded by evil. Low on gas...
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Thanks, Jim. I've got the factory overhaul manual, which should be enough.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I rebuilt the ZF steering rack in my BMW a while ago, it was complex but actually pretty easy, since I just dissasembled it and replaced whatever gaskets and seals I took out with a matching one from the kit, which did not contain instructions. Those racks are $400 rebuilt, the kit was $70 and it took me all afternoon, but it has held up for about 50,000 miles no problem.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2004 Posts: 22 Junior Member | | Junior Member Joined: Oct 2004 Posts: 22 | fred i do suggest one very important thing ...
put a bunch of magnets around the area you are working on the steel bench , the small parts don't end up as far away
ha ha chuck | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by canadian: fred i do suggest one very important thing ...
ha ha chuck But if I do that my head will be stuck to the bench because of my tin foil hat!
