4 members (Brian Moore, walter74, J Lucas, Jims46), 62 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#174967 03/30/2005 2:02 AM
I have a 46 2-ton Chevy truck and wondered if any of you have tried or know much about installing those bent 1 piece windshields instead of going back with the stock frame and seal?
The price looks to be comparable especially since I'll have to replace everything.
Glass, frame, seals and crank set up that opens
the bottom out. At this point I'm not too sure if I even want the windhield to open.
Thanks for any info.
1946 Chevy Flatbed 2 Ton Truck
1950 Chevy 3100 5 Window Cab P/U
1968 Chevy CST
1972 Chevy Fleetside Longbed
1992 Chevy Scottsdale Ext Cab
2000 GMC Sierra Ext Cab
#174968 03/30/2005 2:32 AM
FCMullins,
My 2 cents. My want to check EBay under CAR,PARTS & Other's.
Do" 46 Chevy" under search and look for...
Door Glass RH & LH #4539514725. Toward the end
9 Days left!
Or "smith hot rod glass".
cvett
#174969 03/30/2005 2:47 AM
Depends on your goal. Are you keeping it original?
I kept the original windshield AND the crank. It is one of the most talked about items on my truck at the shows. Mainly because it seems EVERYONE does what you are thinking about doing and you just don't see the original cranks anymore. Not to mention, there are only a few vehicles with this option in the first place.
If you decide to stay original, I'll help you out on the info you need.
Timmer
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#174970 03/31/2005 1:13 AM
Thanks for the info.
I'm really thinking of going back original.
I have the handcrank assembly but the shaft is stuck which shouldn't be much trouble. The only obstacle might be the gears which look a bit stripped. I do however have the stainless tape and it appears to be in good shape.
I too like the look of the original windshield.
I'm not looking to have a show truck just one I
can drive around and enjoy now and then!
Frank
1968 Chevy CST
