| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17495 07/15/2002 1:09 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | How can I clean a engine with caked on grease and dirt. I tried engine degreaser and it works a little. What can I use? | | |
#17496 07/15/2002 1:30 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I have always had the best results by trying to scrape off the caked on grease with a putty knife and a wire brush. Unless you use high water pressure, de-greasers will not remove caked on crud.
Get the heavy stuff with the putty knife and then follow with the de-greaser.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#17497 07/15/2002 2:13 AM | Joined: Jul 2002 Posts: 17 Member | | Member Joined: Jul 2002 Posts: 17 | Well here is a solution if the engine is not in the truck  . Ez-Off Oven cleaner. Dont laugh , It works. But be forewarned it will take off everything, I mean everything off. Including nice shinny paint. Do not get this on your paint! Good Luck Ed | | |
#17498 07/15/2002 10:26 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Call me even crazier but strong paint stripper works great. But of course it strips paint also. Brush it on the engine let it sit and rinse it off.
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
#17499 07/16/2002 3:38 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | I would go along with 53 4 me's suggestion, except I like to use " Castrol Super Clean". Easy-off is cheaper, though...........it's just kerosene and lye.......... Don't get any of the above mentioned products on your hands, it will eat them up big time!
*** GMC ***
