2 members (Nick in Manitou, 1 invisible),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | I have a 51 1/2 ton , but its been reworked so I am unsure if everything is original '51. For instance...it has a 235 straight six, so thats certainly not original.
I have a small master cylinder leak. Chevyduty.com has master cylinders for the '51 and another for the '52-55. Frankly...they look identical and they both have 1 1/8" bore, so I'm unsure what to order. Is there a sure fire way to determine if the cylinder in my truck is indeed a '51?
Thanks. | | | | | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | The '51 cylinder should have the brake line screwed directly into the head nut (big outlet adapter that screws into end of cylinder) with a 7/16"-24 tube nut. On the '52-'55(1) cylinder, the head nut is tapped 1/2"-20 and will probably have a banjo bolt and fitting, though some may be set up for 1/2"-20 tube nut with a brass tube seat pressed into the head nut.
Joe | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | According to 1929-1954 Chevrolet Master Parts book, the 51-52 Master Cylinder has the number 341 stamped on the Master Cylinder followed by the letter "H". The 53-54 Master Cylinder has the same number stamped on the Master Cylinder followed by the letter "J". However, the 53-54 Double Duty also uses the same Master Cylinder as the 51-52. That Part Number is: 5453837. The Part Number for the 53-54 is 5454022. :confused:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | thnaks you guys...i'll turn this over to my mechanic friend who speaks this language. much appreciated. bart | | |
