1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#174899 11/18/2004 1:06 PM
I need some help with my daughters S-10. The truck is a 95 with a 4 cyl 5 speed. You can shift it into all the gears but 4th is the only one that the clutch engages in , it will drive forward in 4th if you bring up the rpm's. I was thinking the clutch , any ideas?
On a T-5,only 4th is a direct drive through the mainshaft,in all the other gears, the drive is through the cluster gears.Drive in 4th only must mean the front input shaft gear is history.
If the clutch is broken or worn,it would drive in all gears besides 4th to some degree.
Got gear noise to go with that suspected bad clutch?
FWIW, lots of great S-series info at http://forums.s-series.org/index.php
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
scott, nice link, thanks for posting,,Fred
Redryder pix
My Hotrod
No gear noise ,and fourth shifts smooth , don't know that much about standard transmissions,how hard is it to fix? Thanks for the quik response!
I am by no means a tranny man, but I recently talked with a fellow who had a similar problem. A rollpin broke in the shift fork assembly allowing the shifter to move and feel normal but not moving any clusters, or gears! Good luck.
Atomarc.
I know nothing about trannies, but I did stay in a Holiday Inn last night...
54 3100 with 235
62 flatbed dump C60 with 261
and so what can you tell us about that experience,,did ya get everthing fixed??Fred
Redryder pix
My Hotrod
Something happened to the input gear of your countershaft. I'm not sure how Chevy does theirs, but other makers use keyways to assemble the input gear to the countershaft and they can strip and the only gear left will be 4th. I hate to tell you but, I'm afraid the trans has got to come out,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Well I pretty much figured the tranny would have to be removed , I will pull it apart myself and see if I can figure it out soon.
