6 members (Paul_WNC, Gdads51, Shardean, Greg_H, NorCal52Suburban, Waveski), 60 guests, and 6 robots.
Topics128,021
Posts1,055,357
Members48,420
#1745 02/08/2005 5:42 PM
the teeth on my flywheel for my 292 is ground up bad. i was wondering which engines use the same flywheel as the 292 so i can switch it out? im guessing right now that 230, 250, 292, and maybe even the small block v8s all share the same flywheel. am i right anybody?
#1746 02/08/2005 5:53 PM
flywheel to crank bolts on 292 are 1/2" and the 230/250 flywheel are 7/16" dia.
#1747 02/08/2005 6:14 PM
cool, so i guess the smaller inline sixs are out, what about the v8's?
#1748 02/08/2005 7:32 PM
I'm pretty sure the ring gear is the same for all 230-250-292 flywheels (and maybe even V-8's) so you can just replace that and keep your flywheel. You can remove it by heating it up with a propane torch and tapping it off with a hammer. Heat the new one in an oven or bbq grill to about 200 degrees and drop it on the flywheel. Be careful not to burn yourself.
Paint & Body Shop moderator
