| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I finally have all of the sheet metal on the front of my 1950 GMC 2 ton but the hood seems like it is 1/2 too long. The rear gap is about 1/8 inch and the sides look good but the only way I can latch the hood is to push back pretty hard and then its a trick to get it to release again. I can't see any adjustment for the front plate and latch. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | I got a shop manual from Chevyduty for mine and it has a page of instructions on adjusting the hood...It's all in the hinges and support arms.you leave a couple of bolts loose until you get the hood squared up then tighten all down...the book is worth it's weight in gold...
Geoff
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | To adjust the hood we had 3 people helping. One on each side to tighten or loosen the bolts and one in the front to push it back toward he cowl. Another idea is to check the play in the hinges. Sometimes there is too much slop and you cannot get the hood to fit no matter how much you adjust. If I recall the latch plate is on elongated holes so it could be adjusted a bit. I put a scribe mark on the shrould so I could see where I was adjusting it. | | |
