2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#174692 01/26/2005 4:28 AM
ok, I hope this doesn't sound ignorant.... but umm.... my 49 chevy 3600 only has a keyhole on the passenger side door. this doesn't make any sense to me. Could it be a different door from a different year? Thanks.
#174693 01/26/2005 4:46 AM
well, it does seem a little goofy from todays perspective, but that's the way all the trucks were up to the 60's - you can switch the keyed handle to the drivers side if that makes life easier for ya, or you can even get another lock setup for the 2nd side
I think it originated because it was 'safer' to enter and exit the vehicle on the off-road side
#174694 01/26/2005 9:24 PM
The door lock thing was required by law in some areas until the '60s - you weren't supposed to exit a parallel-parked vehicle except through the curb side. Therefore, you locked the driver's door from the inside, and climbed out through the passenger side.
If your '49 still has the drop-down handle doors, you're mostly stuck on the door lock. The only way I know of to get a driver's side key lock is to switch to doors with the push-button handles and vent windows (1952-1955.1). I think there are kits to eliminate the vent windows on those doors. If you have the push-button doors handles, you can have another lock button keyed to match your original lock button, and have one on each side.
1954 GMC De Luxe COE
#174695 01/26/2005 9:34 PM
Jed Offline
Old Car and Truck Nut: Thanks for posting the question. I've wondered that same thing a couple of times myself. Here's one for the curious, my 46 has one lock on the passenger side, like your 49. However, my 52 has a single lock on the driver's side. Never has made sense to me. Good luck with your project.
#174696 01/26/2005 11:32 PM
Thanks guys, your explanation was what i wanted to hear. I'm restoring the truck as an original so the lock will stay on the passenger side. smile
#174697 01/27/2005 12:11 AM
Jed, a past owner swapped the lock button from the passenger side to the driver's side. You can get another button from anyone who sells used parts, and get it re-keyed to match your locks at any locksmith for a small charge.
#174698 01/27/2005 12:19 AM
Jed Offline
GMC Panel, Thanks for that piece of information. I've been confused about that one for a while. Just never made sense, and never thought to look at another truck when I had the opportunity. The getting another lock for the passenger side is a great idea. Old Car and Truck Nut... I guess what they say here is true. There are no dumb questions. If you're wondering, chances are that someone else is or has in the past.
#174699 01/27/2005 2:02 AM
hey, guys. some new chevy are like that. my son's
2005 chevy colorado, only has a key hole on the driver's side.
i guess, new is old again.....
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
