10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#173850 04/26/2005 3:12 AM
I came across a pair of parts for my 1950 GMC 2 ton and I can't for the life of me remember where they belong.
http://pg.photos.yahoo.com/ph/rdbates1/detail?.dir=7991&.dnm=c686.jpg
#173851 04/26/2005 4:43 AM
This must be something for larger trucks. If no one on this forum contacts you go to:
http://www.oldgmctrucks.com/index.html
You will have to sign up, but its free. It's all GMC and I'm sure someone there can help you. Cecil........
#173852 04/26/2005 4:43 AM
Those look like the blades for the optional under-mounted lawnmower!
Brian
#173853 04/28/2005 1:41 AM
Anonymous
Unregistered
Anonymous
Unregistered
I know what those are!!! My 53 has them too, except they are connected to three other parts. This main piece is the part that goes in front of the inner fenders and radiator below the hood latch. The grille sits above/in front of it. Those are the two pieces that slide in between the rad support and the inner fenders from infront. Their are two bolts that are close to each other that go into the rad support, the one end of your pieces get bolted right inbetween their. Make any sense? I'm trying to find a picture but can't seem to come up with one...
#173854 04/29/2005 1:38 AM
Thanks Articatgmc53 grin I thought they belonged up front but its been too long since it came apart. For the next project, I am going to take more than progress pictures.
