5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
#173671 12/23/2004 10:25 PM
Has anyone ever put shoulder belts in a '60-'66 truck? If so tell me what type vehicle you used as a donor for the belts. Are there any after market kits available to install full shoulder belts? I'm going to use this truck as a daily and just want to make it as safe as I can.
Mike
#173672 12/23/2004 11:09 PM
Got my aftermarket belts for my 64 from GEM Streetrods.
Had to drill the upper holes in the cab for the shoulder harness, then secure a nut in there, but not too bad all-in-all.
Also had to drill the floorpans for the retractor... and there is a nice place moulded iin the floor for it on the driver's side.
Sittin' Pretty in My Old Kentucky Home.
http://www.picturetrail.com/barneysbowtie
#173673 12/24/2004 12:56 AM
Thanks, I checked them out and that's the cheapest kit I've seen so far and exactly the same as all the others.
Mike
#173674 12/24/2004 1:57 PM
I welded a 1/2-20 nut to a large cab mount washer & welded it inside the upper pillar so the nut would not pull through in an accident. I am using belts from Andover restraints. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
