0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | Has anyone ever put shoulder belts in a '60-'66 truck? If so tell me what type vehicle you used as a donor for the belts. Are there any after market kits available to install full shoulder belts? I'm going to use this truck as a daily and just want to make it as safe as I can.
Thanks, Mike | | | | | Joined: Jan 2001 Posts: 55 Member | | Member Joined: Jan 2001 Posts: 55 | Got my aftermarket belts for my 64 from GEM Streetrods.
Had to drill the upper holes in the cab for the shoulder harness, then secure a nut in there, but not too bad all-in-all.
Also had to drill the floorpans for the retractor... and there is a nice place moulded iin the floor for it on the driver's side. | | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | Thanks, I checked them out and that's the cheapest kit I've seen so far and exactly the same as all the others.
Mike | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I welded a 1/2-20 nut to a large cab mount washer & welded it inside the upper pillar so the nut would not pull through in an accident. I am using belts from Andover restraints. Brian | | |
