2 members (sron48, Gray_Ghost),
105
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 4 Junior Member | | Junior Member Joined: Sep 2004 Posts: 4 | I've been investigating upgrading the master cylinder on my son's 60 chevy to a dual master cylinder (I can't afford the disc brake packages yet). I see references to using a 68 pu master as a replacement but when I compare the two the bolt patterns don't match. Is there some adapter plate that needs to be made or am I missing something? Is there a direct bolt in that is better?
Thanks in advance for the help. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | check out the kit at www.mpbrakes.com | | | | | Joined: Sep 2004 Posts: 4 Junior Member | | Junior Member Joined: Sep 2004 Posts: 4 | Not sure which kit you're refering to. I see some master cylinders however they appear to be similar to the '68 m/c I've seen at the parts store. The bolt pattern doesn't match the bolt pattern of the original m/c. Is there something I'm missing here? | | |
