4 members (tclederman, Peggy M, Cletus1950, Charles in CA), 139 guests, and 13 robots.
Topics128,106
Posts1,056,217
Members48,436
Junior Member
Junior Member
I've been investigating upgrading the master cylinder on my son's 60 chevy to a dual master cylinder (I can't afford the disc brake packages yet). I see references to using a 68 pu master as a replacement but when I compare the two the bolt patterns don't match. Is there some adapter plate that needs to be made or am I missing something? Is there a direct bolt in that is better?
Thanks in advance for the help.
Z
Z Offline
check out the kit at www.mpbrakes.com
Junior Member
Junior Member
Not sure which kit you're refering to. I see some master cylinders however they appear to be similar to the '68 m/c I've seen at the parts store. The bolt pattern doesn't match the bolt pattern of the original m/c. Is there something I'm missing here?
