4 members (frogfarmer, dt235sd, Frank50, 1 invisible), 267 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
Junior Member
Junior Member
I've been investigating upgrading the master cylinder on my son's 60 chevy to a dual master cylinder (I can't afford the disc brake packages yet). I see references to using a 68 pu master as a replacement but when I compare the two the bolt patterns don't match. Is there some adapter plate that needs to be made or am I missing something? Is there a direct bolt in that is better?
Thanks in advance for the help.
Z
Z Offline
check out the kit at www.mpbrakes.com
Junior Member
Junior Member
Not sure which kit you're refering to. I see some master cylinders however they appear to be similar to the '68 m/c I've seen at the parts store. The bolt pattern doesn't match the bolt pattern of the original m/c. Is there something I'm missing here?
