1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#173283 03/27/2005 3:11 PM
After over two years restoration, it came down to priming the oil pump, and bringing Dusty back to life, yesterday. Wiring was all checked and everything looked good. Timing light was hooked up ready to set the timing once it fired up. Choke pulled back to get gas to the carb. Key switch on and the moment arrived--pushed the foot starter. The motor turned over and over a few times (didn't start) and I stopped and gave the starter a rest. After a few minutes, tried again---and sparks flew from both the battery POS post and the starter silonoid (sic). :confused: Waited a few minutes and tried again--same results with the sparks. :mad: Put the truck in gear and rocked it back and forth a few times, and tried again--SAME results! :mad: :mad: Pulled the starter and noticed the teeth in it were worn and a couple teeth broken. Instead of trying anything else, I "fired up" the computer and placed an order for a new starter from Jim Carter. Should be here by next Wednesday, and after installation, will try again Saturday to attempt another start up. On the bright side, this will give me another week to shine Dusty and prep him for our Car Club cruise in on the 8th. of April. grin My goal was to get him ready by then, and looks like plenty of time to do it. Wish me luck!!! wink
#173284 03/27/2005 5:05 PM
Good luck!
Gravity - It's not just a good idea, it's the law.
#173285 03/27/2005 10:06 PM
I know how frustrating that can be...
You'll get there.
But...
Pictures, man. Where are the pictures?
You CAN'T lead in with talk of a two year resto,
and not give us pictures!
It just ain't fair!!
Cheers,
mark.
'51 3100
#173286 03/27/2005 10:43 PM
Hey 51! Take a look at my profile and you'll see Dusty in all his glory! Also pictures in the gallery under '56!
#173287 03/28/2005 3:09 AM
Beautiful!!
You must be proud.
I really like the white paint (matching the grill) around the headlights -- really a nice touch you don't see too many people doing these days.
Cheers,
mark.
#173288 03/28/2005 3:59 AM
he had to, he ran out of black paint
Redryder pix
My Hotrod
#173289 03/28/2005 9:37 AM
Hey, Brian
That's a great looking truck, man! And, Mark really said it -- that white trim around the lights is a great touch!
Well ... it's late-night Sunday ... how'd things go?? I'm looking forward to hearing you say "Dusty runs great!"
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#173290 03/28/2005 11:41 AM
Looking fine Brian! My 56 is the same model... right down to the fender mounted spare. I'm doing the same with the white trim.
Larry Bear
55.5 Chevy 3100 Panel
#173291 03/29/2005 12:27 AM
Thanks for the nice comments all. An update--I called Jim Carter to check if they were processing my order, and low and behold, was told they did not have any in stock. I could send them my old starter and they would rebuild it but a long turn around time. Cancelled the order, and contacted a couple others with no luck. THEN called the Filling Station--they had one, shipped it today, and i should have it not later than Thursday. Real anxious for Dusty to "hit the trail"!
