9 members (Charles in CA, dt235sd, jmoore, Jay R, Southerntruck, Flatblu4748, tclederman, 5cameo8, 1 invisible), 72 guests, and 3 robots.
Topics128,128
Posts1,056,683
Members48,452
When I drive my '66 C-10 in heavy rain, the fan sprays water on my distributor cap and wires. Does anyone else have this problem? frown
Doug 57.
Is the fan shroud missing?
This truck has a 250, and apparently never came with a fan shroud. I've seen several other C-10 Pick-ups with the inline six without it. Were fan shrouds used on '66 C-10's with 250 inline six engine?
Doug 57.
I've never seen a 60's 6cyl w/ a shroud, but there may have been a small sheetmetal piece or 2 somewhere to deflect water, and I think there should be some rubber stuff around where the suspension hits the bottom of the inner fenders - doesn't necessarily hafta be 'sprayed by the fan' [unless you've had somebody ride under there to watch! grin ]
Want to volunteer? grin
Doug 57.
I had a 69 that did that. It sprayed water from around the front wheels. Did that since it was new. I found a piece of fairly heavy but flexible plastic and wrapped it around the distributer with a tie wrap. Made it as high as I could and cut notches for the wires. It solved my problem. Did'nt look like much but I could run through a puddle without killing the engine.
I like old trucks
Going to an HEI solved it on mine, its taller. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
