9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#172287 11/27/2004 6:55 AM
Apprentice
Apprentice
what i am wondering is it better to try to rebuild your cylinders or just get new and can any one tell me if napa or any other parts store has them or the rebuild kits for them for a 1940 1/2 ton
1940 1/2 ton chevy
Napa or CarQuest should be able to get the cylinders. Personally, I like to replace brake parts rather than rebuild, although I have rebuilt some later-model car calipers. If you do rebuild, make sure they are working properly - don't cut corners with anything that can affect your ability to stop or steer!
1954 GMC De Luxe COE
If you can afford it, it's best to buy new. Wheels cylinders are pretty cheap so I wouldn't rebuild one of those but I might rebuild a master cyl if it's in good condition and cost a ton for a new one.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
The best prices for rear cylinders for my '46 were at Advance Auto parts. They were in the next day too. Shop around.
Gravity - It's not just a good idea, it's the law.
Riding in the Passing Lane
I may be old fashioned but I always rebuild my
wheel cyls. Unless it is too rusty & corroded.
It only takes a few minutes. You can buy a hone
for less than 10$. If there is some pits
toward the center it doesn,t hurt. The cups don,t
ride in that area. smile
1972 Chevy c10 Cheyenne Super
I have rebuilt a lot of them and never had any problems, However I did have to replace the master cylinder on my 54 GMC one ton because it was rusted beond repair.
I like old trucks
Justin, I'm in the middle of redoing the complete brake system on my 40. My brake lines were rusted thru and the rest of the parts like the springs had served there time. I got all the parts except the drums (I turned the drums) for just under $500. The lines I found out are 1/4" dia. and you can get them from Napa. They will cost a little more at Napa than if you get them from Eastwood. the rest of the parts I got from Jim Carter and Chevys of the 40's. It's too bad but you can't get everthing from one site.
Good luck.
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
