| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 2 Junior Member | | Junior Member Joined: Mar 2005 Posts: 2 | would any one know what disc rotors fit on the front axle of a 57 1/2 ton chevy truck. :confused: | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | you can buy a disck brake conversion braket kit from classic performance products. | | | | | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Are you replacing some disc that were already on the truck?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a variety of different ones are possible, depending on the adapters used, most of which use modern 5 bolt stuff , tho' I have seen some that take 6 bolt someplace Bill | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | Most of the newer trucks that have 6 lugs and a hat style rotor will fit. Modifications may be required. For example, the center hole in the rotor will have to be enlarged. I was looking at the rotors and calipers off a Toyota 4Runner the other day and I think I will use those. The calipers are 4 piston, makes the caliper bracket easier to install. | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | So you are saying the 4 Runner front disk will fit the six bolt Chevy hub. Then one would need to modify for the caliper? I am interested in this. I have a 52 GMC Suburban and want to change the front end to disk brakes and keep the conversion on the "economical" side of things. I know they sell a kit that does the whole shebang for about $400.00 but I do not wish to part with this much at the moment. I did see a post somewhere, where a dude put the front disks from a Nisson Hard Body on a truck and used a MII master cylinder. I think he had to make some sort of bearing spacers too. I will have to try to find the link to that one article.
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | BigSix302 I used a disc form a mid 70's 4 wheel drive chevy on my 53. I used the origenal hub and just replaced the bearings to the roller type. I also used a dual master cylinder from a mid 70's truck without a power bouster. Had a bracket made for the spindles and it all bolted right up. I went with these parts because they are readily available and they are cheap. | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Oh I forgot to tell you that this kept my 6 lug pattern. | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Sorry...haven't been here in a while. City came down on me for too much stuff sittin around. Been workin to clean things up. Sorta forgot about the post here. But anyway...that sounds really cool! I will have to get otu and see what I can find for that conversion. Did you take any pictures of the install? I am really Jonesin to do this this spring sometime. I would like to start working towards getting it all ready to bolt on. Thanks for your input too by the way.
| | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Fat Fenders,
You said you had a bracket made for the spindles. Did you take it to a local shop? Who did your design? I'm in the same situation. I'd like to update brakes without changing front end.
jay
Your lack of preparation is not my emergency
