Brrrr
place holder
3 members (Otto Skorzeny, Sjm, DennisM), 163 guests, and 6 robots.
Topics128,271
Posts1,058,415
Members48,485
#172042 03/11/2005 11:30 PM
I might be upgrading to a 700R4 and I was wondering, do I need to remove the whole engine to replace it? I hope not, cause I don't have a hoist.
Also, I might paint it. I know I'll need a high-heat tolerance paint. What's a good brand/type to go with? Thanks
GO RANGERS grin
Photos Updated so check them out!
#172043 03/11/2005 11:55 PM
Riding in the Passing Lane
What engine is in it? What year truck? smile
1972 Chevy c10 Cheyenne Super
#172044 03/12/2005 12:08 AM
Well....DANG I know I'm not supposed to ask questions if it's not a pre-73. But it's an 85 305V8. It's open driveshaft. Originally a TH350.
Sorry Peg frown hehe
GO RANGERS grin
#172045 03/12/2005 5:13 AM
Ok... here goes....
It bolts right in, no problems. rear mount may be different, probably not. You need a new 700R4 converter, and wiring for the lockup. (they sell kits for this at Summit,... )
Driveshaft should be same, so is yoke, usually.
Here's the killer tho..... DO NOT FORGET to buy the carb. kickdown adapter to lengthen the throw to the kickdown cable. (Also known as throttle pressure cable). You will never get it just right without this....... I learned the hard way!
If you decide to buy a non-lockup converter, make sure you get the non-lockup valve mod kit for the trans also...... about $30 or so. Dont do that if your hauling loads tho........ builds up heat!
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
