6 members (Tronman, wilbur53, Jon G, GMCJammer51, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
I
I Offline
I swapped out the torque tube and tranny in my 52 chevy coupe for 56 rear end and saginaw 4 speed today. The tranny was wet (at least a little bit)as was the rear, but I drained them and need to know how much to put back in each. Anybody know?
I plan to use 80/90 weight in each, any real benefit to the redline stuff or is it just a bunch of hoopla?
Chris
I, myself was wondering about quanities and viscosity for a 1947 chev, 4400 series 1&1/2 ton. And exactly is this redline stuff u spoke of? I dont know what a torque tube drive-line is, but I know that my drive-line is open, do u think that this has been changed out? It seems like I've heard many others comment about that too!
49' Chev, 3808 platform
Rear ends and manual transmissions usually call for lubricant to be added to the bottom of the fill hole. i.e. when it starts runnin' out, it's full! smile
Oops, a quick check of the shop manual says its should be 1/2" down from the filler when cold. At the bottom of the filler hole when at operating temperature.
1-1/2 and 2 ton trucks went to open driveshaft about 1941.
1-1/2 & 2 ton single speed rear end holds 12 pints of lube. 2-speed holds 14 1/2 pints. 4-speed transmission holds 6 pints. Both use S.A.E 90 "Multi-Purpose" gear lubricant.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
do all rear-ends have drain plugs? :confused:
Thad,
I'd guess most of them DON'T have drain plugs. I just checked all the rear ends in my shop and none of them have drain plugs (including my '38 1-1/2 ton). On rear ends with the rear cover, it's just a matter of pulling the cover off and letting it drain.
On the Corvette (same as 55-64 passenger), there isn't a rear cover so you either pull the axles and loosen the center section or NAPA sells a suction gun that you can use to remove most of the old lube. The gun also works for putting lube IN if the fill hole isn't accessible otherwise.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
thanks Olblue, I thought I was just missin' it. Do u think that I can still find the replacement gasket if I remove the 10 bolt rear-end cover?
Thad , you could just take the bottom bolt out and leave it to drain out . It takes ages .
Then you save a gasket .
Taking the cover off , means you have a pattern on hand , (the cover) to cut your own gasket , an easy task , just take your time .
