Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#171998 03/04/2005 2:32 AM
I took the glass out of the metal frame the other day and on the top edge of the glass that goes into the metal frame there is a rubber channel and on top of the rubber a strip of felt. I would like to replace these but have had no luck finding these pieces in any of the vendors. Any suggestions
Thanks, Stuart
#171999 03/04/2005 4:41 AM
I had the same problem. It's out there, but not under the 'category' you'd think. Like gasket, or rubber, or stripping.
Jim Carters or Chev's of the 40's got it.
Look under "glass setting tape"
It comes in 2 thicknesses, so if you get the thicker one, you will not have room for the felt.
Timmer
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#172000 03/04/2005 5:30 PM
Thanks Timmer. I will have a look
#172001 03/05/2005 6:21 AM
Does your glass fit into a metal frame? Then is there a window channel around door that it fits into? If so the rubber seal you are looking for is hard to find. I used a lot of silicon spray and softened mine. You might try a glass shop, and see if they have something that they use to set glass in metal framesthat is close.
#172002 03/05/2005 8:45 AM
Molly45
Yes the glass does fit into the metal frame, but first it fits into a rubber channel with a felt strip on top of the rubber. I think that i will clean mine up also as I am having a hard time locating this
