0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 18 Junior Member | | Junior Member Joined: Nov 2003 Posts: 18 | Does anyone have a picture of a parking brake attached to the rear brakes? I've got the cable, I'm just not sure how to install it since my truck didn't come with parking brake cables on either side. | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | OK, don't know what year or size your truck is so, your mileage may vary. This article and pics are for a '55 1st series 3100 (half-ton) Emergency Stop Mr. Scott! | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | just hooked mine up this past week but sorry no pics. the parking break lever is behind the shoe and pivots on one end. the other end has a "u-shaped slot/bracket" on it. your new cable should have a spring on it with a metal end piece. pull the spring back sway from the metal end piece and expose the cable and then push the cable into the slot and then release the spring. you have to be holding your mouth just right! is that clear as mud?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | yeah... what year truck... chevy or gmc? half ton, 3/4 ton, stock, hot rod, what? let us know, and we'll try ta help... -W | | | | | Joined: Nov 2003 Posts: 18 Junior Member | | Junior Member Joined: Nov 2003 Posts: 18 | I appreciate the help guys...It's a '54 chevy 3/4 ton. | | |
