2 members (60steve, 78buckshot), 75 guests, and 1 robot.
Topics128,212
Posts1,057,468
Members48,471
OH YEAH....I like it! I've seen a couple of pics in the past with one of these.
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
Socket Breaker
Socket Breaker
whew.
for a minute ftyler I thought you'd done slung some rods man! eek
-W
p.s. mebbe I can talk pop into puttin' it on his '57 235 in his '53. he he he (fat chancE!)
Interestin piece of equipment.I've talked a lot to Leo Sanducci who has the book on modifying 292 Chevy 6's. When he first started drag racing,he was using a 261 Chevy,heavily modified stock head,turning 6000 rpm.Tons of money and maybe 290 hp for an all out drag motor that runs only for 13.5 seconds.But he never mentioned crank or rod breakage.He claims a turbo or mechanical supercharger on an engine like a 235/261 makes sense,get good power despite the poor head design.And make the power at lower RPM's,much less stress on the rods and crank.Of course this requires expensive forged pistons,and the easily adapted better GMC oil pump.But mistakes with supercharging can ventilate the block or pistons in a NY minute if the boost is too high causing detonation,but if ya got money to burn on old engines......................
Let me see?Quickest way to blow up a 235 or 216.Take it out to the back 40.Start it up,put a brick on the gas pedal holding it to full throttle.Then back off about a hundred feet and watch.
or just let my wife drive it,,,
Redryder pix
My Hotrod
Quickest way to kill your Chevy is:
Tryin to keep up with a GMC
Dale: I know a guy who tied to blow up an Austin that way. The poor thing screamed for about 1/2 hour, didn't blow up, so they gave up and shut it down. He thought - oh well, maybe the car isn't so bad, so he drove it for about a year and then sold it.
I guess in stock form, engines can handle that type of abuse. I think he should have advanced the timing as much as possible before the "run" -that should do it!
Gord
1954 1/2 ton 235 4 speed
Trying to keep up with a GMC,I take it you are talking about them Chevy rejects That they sell as GMCs.
Junior Member
Junior Member
Maybe I'm missing something here but aren't most of these blowers "GMC" products, like the 4-71, 6-71, etc. If it's good enough for a GMC then it's good enough for a Chevy.
