9 members (3B, Johnny Rib, baldeagle, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer, walter74),
108
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | Are the Chevy truck hoods from 47-55 1st all the same? Thanks Mac | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Sorta...The emblem mounting points (I believe) are different. Might be some differences on the internal bracing, as well. :confused: Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | Thats what i thought. The emblems really aren't a problem i can fill and put new holes in if need be. Thanks | | | | | | Anonymous Unregistered | | Anonymous Unregistered | In terms of fit and function the hoods are the same for all 1/2, 3/4 and 1 ton trucks. The 1.5 ton and upward have a different shape at the back corners. | | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | Houston' Thanks that i was pretty sure on also. Thanks Mac | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Aren't the 1.5 and up hoods also longer and bigger curves through the fender area? :confused: Regards, Wannabe
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | guys, yes the 1 1/2 ton and up hoods are longer by approx 3 1/2 inches.but in a pinch you can use the inner rear stiffener/brace on either hood as its the same width. same goes for the front.  | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | also,not to take over a post, but save that old hood. as martin sr would say its the same gauge metal as the rest of the truck. so u can use it as patch panel pcs ...easier to weld together  | | |
